Здравейте ! Имам следния проблем.Трябва да свържа ПИР сензор DSC LC100PI с Digital I/0 NI 6501 със следните спецификации : http://sine.ni.com/ds/app/doc/p/id/ds-135/lang/en и сензора е със следните спецификации :
DETECTOR INSTALLATION
Terminal block connections (Fig.6)
Terminals 1 & 2 - Marked T2 and T1 (TAMPER) If a Tamper function is required connect these terminals to a 24-hour normally closed
protective zone in the control unit. If the front cover of the detector is opened, an immediate alarm signal will be sent to the control unit.
Terminals 3 & 4 - Marked NC and C (RELAY ) These are the output relay contacts of the detector. Connect to a normally closed zone in
the control panel.
Terminal 5 - Marked “ EOL ” End of line option.
Terminal 6 - Marked “ - ” (GND) Connect to the negative Voltage output or ground of the control panel.
Terminal 7 - Marked “ + ” (+12V) Connect to a positive Voltage output of 8.2 -16Vdc source (usually from the alarm control unit).
TECHNICAL SPECIFICATION
Model LC-100PI
Detection Method Quad (Four element) PIR
Power Input 8.2 to 16 VDC
Current Draw Standby: 8mA (± 5%)Active: 10mA (± 5%)
Temp.
Compensation YES
Alarm Period 2 sec (± 0.5sec)
Alarm Output N.C 28VDC 0.1 A with 27Ohm series
protection resistor
Tamper Switch N.C 28VDC 0.1A with 10 Ohm series protection
resistor - open when cover is removed
Warm Up Period 60sec (± 5sec)
LED Indicator LED is ON during alarm
RFI Protection 30V/m 10 - 1000MHz
EMI Protection 50,000V of electrical interference from lightning
or power through
Dimensions 92mm x 62.5mm x 40mm(3.62’’ x 2.46’’ x 1.57’’)
Weight 40gr (1.4oz)
Благодаря ви предварително !
the control panel.
Model LC-100PI
Temp.
Compensation YES
protection resistor
or power through
Weight 40gr (1.4oz)
